- Can you detect our test video? In VSO Downloader, go to Help menu > Online help > Detect my first video now. If you can't detect it, it may be due to a network problem, please contact the support.
Here are tutorials to delete the cache. Click on the one related to your browser: Firefox, Chrome, Internet Explorer.
- The media is encrypted through HTTPS. In this case, VSO Downloader does detect an HTTPS content but can't download it. It will be downloadable in a future update. Meanwhile, you may bypass the problem by using a screen recorder
See here for details
Understanding download errors
- Socket Timeout
- Part size not complete
It means VSO Downloader can't handle the download of the media file. It is possible it will be supported in a future version but we do not know how soon. You can use a screen recorder as a temporary solution, see here for a here for a short list.
Miscellaneous
1 - The video restarts at the previous position so it is considering as a new video and will be downloaded again
2 - The video restarts from the beginning, in this case it should not be downloaded
